Hello all,
does anybody know how to create a 3D CAD model of a tunnel clearance profile along the axis using 3DReshaper?
I have the axis of the tunnel and 2D CAD cross-section (clearance profile) see the picture.
I also have a registered point cloud acquired from a laser scanner (Leica ScanStation).
The aim of my task is to do a comparison of the real state (tunnel lining, technologies like traffic lights, road signs, etc.) to the clearance profile.
Thanks a lot,
Ivo
3D model of a tunnel clearance profile using 3DReshaper
- 3DS
- Full Name: Ivo Kohoušek
- Company Details: SG Geotechnika
- Company Position Title: Reality Capture Modeler
- Country: Czech Republic
- gilles_3DR
- Full Name: Gilles Monnier
- Company Details: Hexagon
- Country: France
- Been thanked: 28 times
Re: 3D model of a tunnel clearance profile using 3DReshaper
Hi Ivo,
The functionality you are looking for is the Extrusion command in the Mesh menu:
Hope it helps!
- Select the polyline to extrude (the green one in the image I attached)
- Launch Mesh/Extrusion
- Hit the "Select 1st path" button and click on the path (the red one in my image)
- Hit Preview
Hope it helps!
- 3DS
Thank you for your a quick answer but it was the first what I tried before. Could you check if it works for a polygonal shape of the profile where is no radius.
Thanks a lot,
Ivo
Thanks a lot,
Ivo
- gilles_3DR
- Country: France
What do you mean by "No Radius"?
What was the result when you tried?
- 3DS
Hello, everything is OK. I have tried your procedure and it works.gilles_3Dreshaper wrote:What do you mean by "No Radius"?
Thanks again,
Ivo
- gilles_3DR
- Country: France
