updated E57 to LAS / LAZ conversion tool e572las
Please post all open source software related items here, eg MeshLab
lastools
Full Name: Martin Isenburg
Company Details: rapidlasso - fast tools to catch reality
Company Position Title: creators of LAStools and LASzip
Skype Name: isenburg
Post by lastools » Sun Nov 11, 2018 10:32 pm
The newest version of e572las.exe not only converts E57 files to LAS or LAZ files but also applies any available rotation and/or translation information to each scan to combine multiple scans acquired from different scanner positions into a coherent point cloud ... (-:
Points from different scanner positions are given different point source IDs so that the information which points are belonging to the same scan is preserved.
http://lastools.org/download/e572las_README.txt
It's part of LAStools version (180919 or newer) and can be downloaded from
http://rapidlasso.com/LAStools
Regards.
Martin @rapidlasso
Re: updated E57 to LAS / LAZ conversion tool e572las
Post by gsisman » Mon Nov 12, 2018 3:11 am
Regards.
Martin @rapidlasso
Nice! We've been waiting for something like this. Moving and exporting to PTS for our other cloud tool was cumbersome.
We'll try this on Tuesday
tomii7
Full Name: Tomasz Gerlich
Company Details: OutPut Precision Ltd
Company Position Title: Owner - 3D Laser Scanning Specialist
Country: PL UK International
Skype Name: tomek.gerlich
Post by tomii7 » Mon Nov 12, 2018 7:48 pm
wow :) this update is huge step for Lastool - '+5'
Best Regards,
Tomasz Gerlich
tomasz.gerlich[at]outputprecision.com tomaszgerlich[at]gmail.com
+44 7756613300
www.outputprecision.com - Reality Capture
www.realitycapture3d.com - Matterport
www.tomgerlich.com
OutPut Precision Ltd, Manchester, UK
fillway
Full Name: Philip Weyhe
Company Details: 3DGS
Company Position Title: CTO
Post by fillway » Mon Nov 12, 2018 11:28 pm
Awesome this is super handy! Thank you!
Philip Weyhe
CTO @ 3DGS.io
linkedin.com/in/fillway
www.3DGS.io
lastools
Post by lastools » Fri Feb 22, 2019 4:18 am
Hello from @LAStools,
also to convert from bulky PTS (or PTX) which are essentially human-readable text files to binary LAS or LAZ files there is a free converter available. If you have a huge PTS file without RGB you can run the free and open source txt2las from LAStools as follows:
Code: Select all
txt2las -i huge.pts -ipts -parse xyzi -set_scale 0.001 0.001 0.001 -o tiny.laz
txt2las -i huge.pts -ipts -parse xyzi -set_scale 0.001 0.001 0.001 -o small.las
if you have a huge PTS file with RGB you can run
Code: Select all
txt2las -i huge.pts -ipts -parse xyziRGB -set_scale 0.001 0.001 0.001 -o tiny.laz
txt2las -i huge.pts -ipts -parse xyziRGB -set_scale 0.001 0.001 0.001 -o small.las
Clayton successfully turned his 315 GB PTS file containing 6,379,507,497 points in ASCII format without RGB into 118 GB binary LAS file. After running LASzip on 118 GB LAS file it went down to a 13.4 GB LAZ file and apparently the Recap software he intends to import this point cloud into does support LAZ.
Going from a 315 GB PTS file to a 13.4 GB LAZ file is a reduction in size by a factor of more than 23. Are there any Leica Cyclone or Geomagic developers on this list? Maybe adding LAZ to the list of supported Cyclone and/or Geomagic output formats might be worthwhile to consider.
Martin @rapidlasso
lastools
Post by lastools » Fri Apr 05, 2019 9:09 pm
The latest version of e572las.exe also handles spherical coordinates and can also apply any pose, rotation, transformation to them to get a consistent LAS output as announced in the LAStools user forum.
Martin @rapidlasso
riso2k4
Full Name: Jordan Rising
Company Details: Flight Evolved
Company Position Title: Co-Founder - CTO
Post by riso2k4 » Sat Apr 06, 2019 3:21 am
Absolutely incredible and so appreciated!
Any idea how the scan position could be outputted from this? It's saving per scan info in the point source ID, but on a large data set with many scan positions, it can be difficult figuring out which scan is which when there is a lot of overlap. A .txt file output with scanid,x,y,z would be fantastic if you are taking suggestions ;).
Thanks again! This was an amazing discovery for us yesterday, saves so much time!
Return to “Open Source Software”
