Best method to generate surface
raynonpo
Full Name: Sphantom
Company Details: Rapid Team Solution
Country: Malaysia
Post by raynonpo »
I have a mesh that have lots of curvy part. what is the best suggestion to obtain the mesh surface by using designx?
geowac
Full Name: Stefan Wachsmann
Company Details: scantaxi.de
Re: Best method to generate surface
Post by geowac »
what do you try to do?
Do you need a parametric model or "only" a nurbs surface?
You can use the auto surface function and manual homogenize the ISO-lines.
Or you can generate small surfaces and combine them to your final model (trimming), or redesign each leaf and copy/rotate them to get a solid, ...
Many approaches are possible ;)
Good luck
Stefan
Return to “Geomagic”
