Geomagic X: boundary fits generate gap
raynonpo
Full Name: Sphantom
Company Details: Rapid Team Solution
Country: Malaysia
Post by raynonpo »
I was trying to use boundary fit on a 3D mesh sketch, however the results shows some gap in between the surface. is there any way to avoid generating the gap or is there any way to fix the gap?
PHughes
Full Name: Patrick Hughes
Company Details: Self-Employed
Company Position Title: Metrology Engingeer
Re: Geomagic X: boundary fits generate gap
Post by PHughes »
The gap is more than likely due to the curve network you are using, have you got any other images you can show me to get some more info. There are a few options when doing boundary fit which will help reduce the gap size. Are you sure boundary fit is the right tool for the job?
Return to “Geomagic”
