Point cloud from SCENE to Geomagic for solidworks
vpul
Full Name: Veli-Niilo Pulkkinen
Company Details: Simetek Works Oy
Company Position Title: Design Engineer
Country: Finland
Post by vpul »
Our company is now testing the Geomagic for Solidworks and question is that how can I bring point clouds from Scene to Geomagic for solidworks? Main problem is that Scene's export file formats are totally different from what Geomagic for solidworks can open, or am I missing something?
Meshes I can bring to GfS without problem ,but how about the point clouds? Because we are using Scene to make separate point clouds to one.
Thx for your help for advance.
Br,
Veli
MiquelCaptae
Full Name: Miquel Estupinya Gaudioso
Company Details: CAPTAE DIGITALIZADO 3D
Company Position Title: DIRECTOR TECNICO
Country: SPAIN
Re: Point cloud from SCENE to Geomagic for solidworks
Post by MiquelCaptae »
Has you tested to import a XYZ (ASCII) format?
Do it first with a little file from Scene. Geomagic don't accept big point clouds.
SAttaya
Full Name: Steve Attaya
Company Details: Geocent
Has thanked: 9 times
Post by SAttaya »
Geomagic's DesignX will take in .fls natively.
You probably will want to install the latest SDK from FARO before you import them.
Register them in SCENE and export to .fls.
Know to work with one of the 5.5 versions
and with the current 6.2.3.9 version of SCENE.
(Don't know about any other GeoMagic products.)
Do know that DesignX has two PT? formats, "?" being either S or X.
vpul
Country: Finland
Post by vpul »
Thx for the replies. I have tried to .xyz , but nothing happens.
Please note that I'm talking about Geomagic for Solidworks -add in, not the Design X
GfS is add-in which you can buy to Solidworks cad-program.
GfS can import Point Clouds (.asc , .scn , .vtx) and Gridded points ( .3pi, .ac , .btx , .gpd , .ptx)
Do I have to use some 3rd party program to convert the point cloud or something?
Br,
Veli
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 »
Scene exports in ptx format, and I venture that if you rename a .xyz in .asc it should work.
WWilford
Full Name: Warren Wilford
Company Position Title: owner
Been thanked: 4 times
Post by WWilford »
For Geomagic Wrap I export VRML from Scene and it brings the point cloud into Wrap with color. It takes a long while to export from scene.
Warren
scan 3D Poland
Full Name: Szymon Bloch
Company Details: scan 3D
Company Position Title: CEO
Country: Poland
Skype Name: szymon_bloch
Post by scan 3D Poland »
we use Geomagig For SolidWorks, but this plugin is dedicated for points cloud in PLY format. This format of point clouds give Optical scanner.
max72
Post by max72 »
If you need to convert to ply use Cloudcompare.
Mind ply can be ascii or binary, can have points or meshes and some importers are picky..
By the way if you never used it, you cannot miss Cloudcompare.. it's a must have tool.
Return to “Geomagic”
