Is there any option in Geomagic that works like the limit box in Cyclone.
My model of a statue has a lot of point inside of where the actual surface is.
This is pretty tedious to clean up manually.
I was wondering if there's a sort of section view where you can play with the elevation of the section in order to clean up easily without deleting faces/triangles that you need to keep.
Anyone here who has some experience with that?
I've attached a picture that shows my current problem.
Geomagic wrap - limit box
- I have made 90-100 posts
- Full Name: Cornelis Kolbeek
- Company Details: 3dszkennelés
- Company Position Title: Scan specialist
- Country: Netherlands-Hungary
- Full Name: James Senior
- Company Details: S-CAN 3D Ltd
Re: Geomagic wrap - limit box
It's under display - view clipping
I'd try using 'Make manifold' under 'Polygons,' or alternately press Select - Select By - Area, and reduce the percentage down before deleting. It may be much quicker.
