Move four registered scans to a GPS location
Discuss all RiScan Pro related issues here.
poley
Full Name: Andrew Poley
Company Details: Boise State University
Company Position Title: Research Assistant
Post by poley »
Hello everyone,
I am curious if there is anyway to shift four registered scans to specified GPS locations (taken with a RTK). I registered the four scans using the GPS locations first (picture 1) but the scans don't seem to align well. If I just register the scans together without the GPS locations all the scans align (picture 2). If I register the scans the second method I still need to have the scans in the correct GPS location for academic purposes, so anyone know of a way to do this? or improve registration using the GPS?
I also tried using multi station adjustment on the GPS registered scans but it didn't seem to correct the problem enough, and scans are still way off.
Thank you,
Andrew
Rikore
Full Name: Bruce Yager
Been thanked: 6 times
Re: Move four registered scans to a GPS location
Post by Rikore »
GPS coordinates can be off depending on the site. Even a tenth or two can cause issues. Register the scans together with out control, then pick two of the GPS coordinates and see if the scans will align to the two. If not pick one and calculate an azimuth to a second. Place the scans on the good coordinate and rotate to the second using the azimuth. Hope this works in the program you are using.
Return to “RiScan Pro & RiSOLVE”
