DXFTruView - Final Version
Discuss and upload any tools here for other members to use.
anonimou
Full Name: Delio Pontes
Post by anonimou »
Hi all,
I finished today the final version that include the 2D elevation option.
Any bugs or other subjects, please contact me.
Délio Pontes
File Remove, see post below
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Has thanked: 49 times
Been thanked: 18 times
Re: DXFTruView - Final Version
Post by Phil Marsh »
Thanks for this Delio I am sure others will find it very useful.
LASER SCANNING FORUM
anonimou
Post by anonimou »
Phil Marsh wrote:Thanks for this Delio I am sure others will find it very useful.
Thanks Phil,
This was a request from a client my, so I have sure one person is using!
I found a bug on the option 2D, New System, the program give the right coordinates but a wrong Length.
I fixed the bug and upload again to the Forum.
Délio Pontes
Phill
Full Name: Phillip Nixon
Company Details: SKM
Has thanked: 3 times
Been thanked: 27 times
Post by Phill »
Delio
Thats really cool. Next time you are updating it can you add a bit to export points (markup coordinates) as well. I'll certainly keep this in mind when show clients truviews. It will save them writing stuff down and the typing it back in again.
Phill
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Has thanked: 23 times
Been thanked: 19 times
Post by stevenramsey »
Hi Delio
In your first post you mention that you can only do line's from the markup's but I think that points are also possible.
<cx:PositionMark FontSize="12.000" FontName="Tahoma" Unit="meters">
<cx:Created>10/14/2009</cx:Created>
<cx:User>rast</cx:User>
<cx:Pen Color="#ff00ff" Transparency="0.059" Width="2.000" Dash="0.000"/>
<cx:Brush Color="#f0f0ff" Transparency="0.875"/>
<cx:LabelPosition>400.0000 592.0000</cx:LabelPosition>
<cx:MarkPosition2D>388.0000 633.0000</cx:MarkPosition2D>
<cx:MarkPosition3D>-1.529643 -0.673333 -1.588327</cx:MarkPosition3D></cx:PositionMark>
Good Luck
Steven Ramsey
Home [email protected]
Work [email protected]
Mobile +44 7766 310 915
anonimou
Post by anonimou »
Hi Steven and Phill,
Thanks for your replys.
And you are right, also the points can be exported.
I will work on that and update the program.
Délio Pontes
pburrows145
Full Name: Paul Burrows
Has thanked: 26 times
Been thanked: 34 times
Post by pburrows145 »
What an amazing little tool - thanks for sharing!
anonimou
Post by anonimou »
Hi Steven,
I remember now why I told, I only can draw lines.
The problem is that some times (and I don´t no why) the xml file exported from leica Truview have different coordinates from the option "markup distance" to the option "markup coordinate" even if you picked the same points with this 2 options.
Example:
Coordinates that I used to draw one line using the option "markup distance":
<cx:FirstPosition3D>4.075118 7.072747 0.417927</cx:FirstPosition3D>
<cx:SecondPosition3D>-0.114275 9.451465 0.464721</cx:SecondPosition3D></cx:DistanceMark>
Coordinates picked in the same place before but using now the option "markup coordinates"
<cx:MarkPosition3D>9.649803 7.858912 -4.791599</cx:MarkPosition3D></cx:PositionMark>
<cx:MarkPosition3D>5.493961 10.234175 -4.728556</cx:MarkPosition3D></cx:PositionMark>
The "markup coordinates" give always coordinates from the "SW system" and the "markup distance" give me sometimes coordinates from the Scan World System and sometimes from other coordinates system and until now I didn´t find how Leica Truview calculate this system and this system change from project to project.
That is why I inserted the option "new system" on my program to the operator if would like move all the project to other system "Scan World System".
So, Is impossible to export the lines and the points all together do a dxf file.
The only way I can remember is to insert a option to export only the points.
If anyone have more ideas please tell me.
Délio Pontes
stevenramsey
Interesting problem and one for the programmers I think.
I will ask around for you.
Steven Ramsey
anonimou
Post by anonimou »
Hi all,
I finished a new version with the option to export "markup coordinates"
Still can´t export the lines and points together to a only dxf file but later can be done easy on Autocad.
I fixed some bugs I found old version and hope not created more! :)
But any bugs found or other subject, please contact me.
Déliio Pontes
dxftruview_2.0.rar
Return to “AutoLisp, Dynamo, VBA, Python & .Net Tools”
