Laser scanner simulation
Discuss all Computer Graphics World (CGI) related issues here.
eburakanil
Full Name: Engin Anil
Company Details: CMU
Company Position Title: Research Ass.
Post by eburakanil »
Hi all,
I am doing research with scanners. I will build a model and actually scan it later. But first I want to simulate the scanner on the as-designed model.
Is anyone here aware of such a laser scanner simulation that would produce a point loud from a model??? A physics engine, some matlab code, or anything would work.
Thank you very much for keeping this fantastic forum up!
Engin
mortted
I have made 80-90 posts
Full Name: Ted Mort
Company Details: Zelus
Company Position Title: Chief Innovation Officer
Re: Laser scanner simulation
Post by mortted »
I assume that the "as design model" is a digital model and not a physical model.
1) (less accurate but essentially free) This is more of a work-around but how about using multiple screen shots of the model and running them through a Photofly type software to create the cloud?
2) (more accurate but potentially cost prohibitive) Use a 3D printer to create a miniature of the model, use a close range scanner to scan. You could then scale up the cloud by the ratio of miniature for a 1:1 result.
If you are referring to a miniature mock-up as the "as design model' then you can still use either option with slight modifications.
Alrawli
Full Name: Al Rawlinson
Company Details: Digital Design Studio CDDV
Company Position Title: Head of Data Acquisition
Country: Scotland
Post by Alrawli »
What part of the scanning process are you trying to simulate? There are lots of different factors to build into a simulation, is this a small or large object mm or metres, what type of scanner are you trying to replicate......... and so on.
Al.
dirdim
Full Name: Michael Raphael
Company Details: Direct Dimensions Inc
Post by dirdim »
I love the previous ideas - Photofly and scanning the 3D print. Very creative, but it's not nearly that hard. Making a point cloud from CAD or a polygon model is a pretty common function.
The high end point cloud processing softwares (PolyWorks, Geomagic, and Rapidform) can create polygons from the CAD geometry. You can then subdivide endlessly, if you wish, to create a massive point cloud from the vertices.
These points will be 'clean', or in other words will not have scanner noise errors. You could introduce those errors via a Monte Carlo routine in Excel, Matlab, or other.
Sounds like a neat project, we've done things like this before. Years ago we simulated the expected overall error of using a 4-ft reach FARO Arm in multiple positions using spheres as mutual reference points. Tons of fun back in the Lotus 1-2-3 days but worked great!
If the CAD isn't too complicated and this is a one-time thing for you, I'd be happy to have our guys make the point cloud for you.
Michael Raphael
Direct Dimensions, Inc.
rapid solutions to 3D problems...
Baltimore, MD USA
410-998-0880
mortted
Full Name: Ted Mort
Post by mortted »
Good call Michael, I didn't think about subdividing the model geometry and extracting the vertices info. Is this an automated function in the software packages that you mentioned or do you have to manually subdivide?
eburakanil
Thanks for your answers guys.
Alrawli wrote:What part of the scanning process are you trying to simulate? There are lots of different factors to build into a simulation, is this a small or large object mm or metres, what type of scanner are you trying to replicate......... and so on.
Al.
Data collection itself :geek: Idealy, I want to simulate one of the commercial sacnners used for scaning buildings, such as Scanstation2, etc. So, the dimensions are in meters.
I also thought about meshing the CAD surfaces and using the vertices. I want to have the occlusion, noise and other effect as realistic as possible. Therefore, I am initially looking for an existig one if there is one.
I will give the photofly a try. It is a very creative idea.
Thanks,
Engin
janos
Full Name: Janos Faust
Company Details: geo-konzept
Company Position Title: Product specialist
Post by janos »
Then use 3D Reconstructor! It has a feature called "virtual scan" that is doing exactly what you want to have!
janos
Has thanked: 42 times
Been thanked: 33 times
Post by Matt Young »
Leica Cyclone has a simulated scanner option.
You basically set up a view of the model and then simulate a scanner position. You can scan the model from various angles and register the scans after.
The above image is a scan I did as a sample fro one of our clients. I just created a model of their logo and scanned it with the simulator.
NVis
Full Name: Niels Vis
Company Details: Alice Labs
Country: Netherlands
Post by NVis »
If you have Cyclone I think that would be the way to go yes. Those virtual scans took very long when I was working with it (Cyclone 5 or 6 it was), so take your time for it.
Also, you might want to add some markers to register to, since I found virtual scans are alot harder to register then the real-life ones.
Niels
pburrows145
Full Name: Paul Burrows
Has thanked: 12 times
Been thanked: 16 times
Post by pburrows145 »
Great tool, as you can simulate range-noise using the preferences in Cyclone... you can see what something would look like using another scanner. I have used this as a sales tool in the past - it works a treat, but definitely needs speeding up!!!
I agree with a few other users that the 'create points from model' in Reshaper/Geomagic et al is also a very useful tool, but does not 'simulate' a scanner - so a perhaps a slight downfall.
Return to “Computer Graphics Industry (CGI)”
