Complex Meshing of Project Point Cloud
Discuss all Forensics & CSI related issues here.
vislaw
Full Name: Mark Johnson
Company Details: Visual Law Group
Company Position Title: Principal and Chief Creative Officer
Post by vislaw » Sat Sep 16, 2017 7:16 am
For our forensic visualizations we almost always convert our point clouds to mesh objects so we can apply lighting & shadows as well as reducing processor load for animation or use with real-time viewers. We recently worked on a forensic case involving a warehouse fire that involved a lot of interior detail that presented a challenge to be able to generate a decent mesh from.
We used a FARO S350 and an X330 to acquire data from 48 scan stations. Here's the project point cloud in FARO Scene 7:
Here are rendered frames showing the completed mesh we made from the project point cloud:
We will use this basic mesh to work with the client to make decisions regarding the final trial exhibits. At that point we will replace much of the current mesh with hand modeled geometry. We will be combining this data with drone-based photogrammetry as well as a data set we created by flying a Faro X330 from a heavy lift drone. For those of you attending the IAFSM conference next month, I'll be presenting more info on the workflow used in this case.
d.raneri
Full Name: Domenic Raneri
Company Details: NSW Police Force
Company Position Title: Crime Scene Officer
Re: Complex Meshing of Project Point Cloud
Post by d.raneri » Sun Sep 24, 2017 10:53 pm
Looks good and sounds like a lot of work! I'll be interested to hear more in Atlanta next month.
LPaulCook
Full Name: L Paul Cook
Post by LPaulCook » Mon Sep 25, 2017 1:41 am
Nice mesh!
Which software do you use for meshing?
L. Paul Cook, PLS
www.LPC3D.com
Oatfedgoat
Full Name: Matthew McCarter
Company Details: Costain
Country: England
Post by Oatfedgoat » Mon Sep 25, 2017 8:52 am
Very impressive looking mesh. Like others, I'd love to know what software(s) and processes were used to create this. 8-)
vislaw
Post by vislaw » Tue Oct 03, 2017 5:22 pm
I used FARO Scene and Thinkbox Sequoia for the meshing here.
madgic
Full Name: Mark Degiovanni
Company Details: 3DUserNet
Company Position Title: Operations Manager
Skype Name: mark.degiovanni.ali
Post by madgic » Wed Oct 04, 2017 10:10 am
The end result is great! Was this all scanned from ground level?
vislaw
Post by vislaw » Wed Oct 04, 2017 9:49 pm
We were able to get a couple scans from the adjacent roof and also elevated the scanner at a couple of points where we could set the tripod on stable structure, but 95% was ground level scanning.
Interestingly, we did fly a FARO X330 using the Stormbee drone and acquired a decent point cloud from the air. However, the Stormbee system currently doesn't support scan colorization (it will before the end of the year) so we decided to not use that data set to build this mesh in order to take advantage of having a color-mapped mesh.
Oliver Buerkler
Full Name: Oliver Buerkler
Skype Name: oliver_buerkler
Post by Oliver Buerkler » Thu Oct 05, 2017 2:18 pm
Congratulations Mark - looks really great!
Could you tell us a little more about your meshing workflow?
What had been done in SCENE / Sequoia?
How did you combine both?
Etc.
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH & Co. KG
oliver.buerkler@faro.com
Twitter: FARO_LS_PM
vislaw
Post by vislaw » Thu Oct 19, 2017 9:21 pm
Hello Oliver,
Thank you for those kind words. A bit late responding here.
The primary point cloud was generated and cleaned in SCENE. I do like to use SCENE to mesh small components. However, for large models I find Sequoia is particularly useful because you can tweak the meshing settings so easily and dial in the level of detail quite easily.
I also separated out portions of the cloud (such as the trusses/support beams) and meshed them separately.
I saved out the mesh objects as PLY files because the PLY format saves vertex colors and brought them into 3ds Max for rendering.
nikitshetti
Full Name: Nikit Shetti
Company Details: Delta V Forensic Engineering
Company Position Title: Senior Forensic Animator
Post by nikitshetti » Mon Feb 26, 2018 6:00 pm
How is the accuracy of the scans when using stormbee drone ? Have they added the colorization option yet ? Also is it possible to align in Scene or you have to use their software ?
Return to “Forensics & CSI”
