DTM extraction
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
DTM extraction
Post by max72 »
From time to time I have to extract ground points from laser scans.
Usually they are small patches with trees, biuldings, ccars, bikes and so on.
At the moment I use a combination of cloudcompare and its rasterize option with arena and arena for rhino to extract the points doing a kind of topographic survey. With that I use my topographic software to extract triangles and contour lines.
I tried to use the lidar module in globalmapper but it is not handling well this kind of noise.
I'm wondering if there are other possible approaches.
Thanks in advance,
colhum1
Full Name: Colin Humphreys
Company Details: Warwickshire Police
Skype Name: col.humphreys
Re: DTM extraction
Post by colhum1 »
Hi Massimo....
We use LSS for PointClouds
http://www.dtmsoftware.com
Colin
brianpgreen
Full Name: Brian Green
Company Details: Green Forensics-Azure Green Consultants
Skype Name: brian.green.forensics
Re: DTM extraction
Post by brianpgreen »
Autodesk Civil 3d has a command to do this.
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Been thanked: 9 times
Re: DTM extraction
Post by gilles_3DR »
Hi Massimo,
We have a special tool in 3D reshaper for that.
Do not hesitate to request a demo version for giving it a try!
Here is a link to a viedo demonstrating this function:
https://m.youtube.com/watch?v=WuINn3q-uls
Has thanked: 45 times
Been thanked: 36 times
Re: DTM extraction
Post by Matt Young »
Cyclone model has a function called points to grid that basically projects points from a defined grid to the nearest (lowest point) of the point cloud at each grid intersection. You get the odd high point that needs to be removed but these are generally easy to spot.
max72
Re: DTM extraction
Post by max72 »
Thanks.
The areas are small, so budget is tight.
Cyclone function looks like Cloudcompare Rasterize. Some editing is required.. for that Arena helps a lot.
I'll investigate the suggetsions.
Thanks again,
