Paper Targets vs. Traversing; Need feedback
scannerdude
Full Name: Terry J. Henry
Company Details: The Beck Group
Company Position Title: Laser Scan Engineer
Post by scannerdude »
Hello All,
I scan mostly buildings with a Leica P20. I use the Cyclone software to do my registration. I have found it much easier on the registration side to bring in a traversed job rather than a free scan job with paper targets. The only issue I am having with a traversing job is setting control points in a occupied building. Unfortunately you cannot scribe X's on a finished concrete floor, so does anyone here have any suggestions on that? I find it much easier to traverse rather than hanging paper targets in the field as well. Just looking for input on field practices for scanning. I get the job done, just looking for tricks of the trade. Hope to hear something back.
andrew.grigg
Full Name: Andrew Grigg
Company Details: 40SEVEN
Company Position Title: Senior Land Surveyor
Country: England
Re: Paper Targets vs. Traversing; Need feedback
Post by andrew.grigg »
I use Tippex (other liquid paper brands are available :) ), which you can scratch off afterwards. Not ideal I know. I think it's possible to combine both traverse and C2C/targets, but I haven't tried this myself, other than creating vertices manually when joining 2 projects.
LEIGH DICKSON
Full Name: LEIGH DICKSON
Company Details: HIGHFIELD ENGINEERING AND SURVEYING LTD
Company Position Title: DIRECTOR
Post by LEIGH DICKSON »
Could you not use this: (They stick to anything - although they may take the paint off of a poor paint job on a wall)
Would your scanner pick this up - can you do a resection?
http://www.phoenixse.com/reflective-retro-targets.html
TimBeach
Full Name: Timothy Beach
Company Details: Hollis
Company Position Title: Senior Associate - Measured Surveys
Has thanked: 3 times
Post by TimBeach »
The P20 wouldnt pick them up to resect on - but you could use them to stick to the conc floor to set up the stations of your traverse over - plus you could remove them at the end of the job.
Has thanked: 45 times
Been thanked: 35 times
Post by Matt Young »
As Tim says, scanners won't like reflective targets, you just get a kind of small very noisy area on them in the scan.
Andrew
Full Name: Andrew Softley
Company Details: Laing ORourke
Company Position Title: Project Land Surveyor
Post by Andrew »
To mark station locations I sometimes use small circular vinyl self adhesive stickers. These are printed with alternating black/white quadrants - the intersecting edges mark the control point.
They do last for quite a while, unless the cleaner hasn't been told not to spend all morning scraping off your previous day's traversing!
There are online companies that will print these for you. I can't remember who we used - search for 'circular vinyl stickers'.
Toulinash
I have made 90-100 posts
Full Name: Cornelis Kolbeek
Company Details: 3d modeling
Company Position Title: Scan specialist
Country: Netherlands
Post by Toulinash »
I have a question when it comes to traversing.
Do you use the special leica targets on the tripod? (center of marker = center of scanner)
And what happens if you get inside and it appears that in one of the stations something has gone wrong, does cloud to cloud registration still work in cyclone when you don't have a lot of bleed? ( is that the right word for overlapping pointclouds?)
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Has thanked: 9 times
Been thanked: 13 times
Post by stevenramsey »
Why don't you not bother marking the ground, Using the two tripods as fixed centers and swap target for scanner. instrument height is zero. You just need to be careful like you would do with a Total station.
Steven Ramsey
Home [email protected]
Work [email protected]
Mobile +44 7766 310 915
Andrew
Post by Andrew »
If the survey will take more than a day I find having control on the ground is a good idea when you come to carry on your traverse. Also, if a tripod was to get knocked during a traverse your life would be a whole lot easier if you had a mark to centre over again.
scannerdude
Thanks all for the informative input.
