A noob question about ortho images from pointclouds
VXGrid
Forum Supporter
Forum Supporter
Full Name: Martin Graner
Has thanked: 6 times
Been thanked: 13 times
Re: A noob question about ortho images from pointclouds
Post by VXGrid »
mjfpfg wrote:
Fri May 31, 2019 7:02 pm
Hi.
I´m starting in the scan world and have one (of many) question related with the subject.
I have a friend that requested me if I could scan a facade of a building for him.
I did the scan (have a BLK360) and the rest of the process (registering, cleaning) in Register360.
My friend needs (cause he does not work with pointclouds) an image of that facade to import to Autocad and then draw on it.
How can i do it?
Tryed in Cloudworx with the command "Ortho image" but the resolution is not great at all.
Thanks.
You can export the point cloud in E57 format and use PointCab to generate your image.
It's really simple:
The description how to generate a section is in the last bullet point at the bottom of the page.
mjfpfg
Full Name: Miguel Guimarães
Company Details: Miguel J Guimaraes - Serv Top
Country: Portugal
Post by mjfpfg »
VxGrid, thank you for the tip.
Saw the link and really apreciated the simple method to do it.
:like: :like:
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 102 times
Been thanked: 21 times
Post by gsisman »
Hi.
How can i do it?
Thanks.
With the New Reg 360 v1.6 You can export to RCP pointcloud directly which he can read that directly with ACAD which will give him a precise facade that he can snap to features on
mariusP
I have made 90-100 posts
Full Name: Marius Putrimas
Company Details: Terra Modus
Company Position Title: Undet product manager
Country: Lithuania
Been thanked: 9 times
Post by mariusP »
Peder wrote:
Fri Mar 08, 2019 4:31 pm
Hi!
I am using:
Register 360
Recap
Revit
Global Mapper
Meshroom (trying it out anyway)
Cloudcompare (trying it out anyway)
You can create ortophoto raster image views from point clouds directly in Revit, using "Undet for Revit" plug in.
Created orthophoto images can be used for Revit modeling or exported using standard Revit Tools.
More info:
https://www.undet.com/for-revit/
https://youtu.be/JMijrpQBAK8
P.S. If you want to create mesh models from scan data and put texture on it, you should try RealityCapture software.
Marius Putrimas
Undet | for a super-smooth workflow with point clouds
www.undet.com
mjfpfg
Country: Portugal
Post by mjfpfg »
gsisman wrote:
Mon Jun 03, 2019 1:38 am
Hi.
How can i do it?
Thanks.
It was the way we tried and worked. I gave him the RCP and after he opened in ACAD. Some problems viewing and rotating the cloud for the facade but after some struggle he did it.
But still I wanted to see how good can the resolution of an ortho image from Register could be.
I´ve bee trying but not really happy with the results...
But thanks for the help :)
bertazizoglu
Full Name: Bert
Company Details: NUBIGON
Company Position Title: Co-CEO
Skype Name: bertazizoglu
Post by bertazizoglu »
I'd encourage you to give NUBIGON a try. It visualizes full-res point clouds as local surfaces combining visual quality with spatial accuracy. You can further enrich the scene with virtual lights, shadows and annotations and even bring in meshes (if applicable) and generate orthophotos from it at desired resolution. Here's a quick demo: https://youtu.be/_g6As6tjbI8 Our two-week trial is available for free from our website https://www.nubigon.com/. Let me know, if I can be of further help.
Bert M. Azizoglu
Co-Founder & COO
NUBIGON Inc.
Email: [email protected]
Web: http://nubigon.com/
YouTube: https://www.youtube.com/nubigon
melshy
Forum Supporter
Forum Supporter
Full Name: Duy Nguyen
Country: Vietnam
Skype Name: duy_bz
Has thanked: 4 times
Post by melshy »
Can use 3Dreshaper and render images orthophotos ;) https://www.3dreshaper.com/en/software- ... a-textures of use Faro asbuilt autocad
DoctaSayas
Full Name: Caleb Sayers
Company Details: VIP AA
Company Position Title: Architectural Designer
Country: US
Has thanked: 3 times
Post by DoctaSayas »
The easiest, easiest, easiest way to do what you are asking is in ReCap. Its easy to switch between ortho and perspective views, and it's easy to export images.
https://knowledge.autodesk.com/support/ ... 4-htm.html
https://knowledge.autodesk.com/support/ ... 6-htm.html
If you're paying for the AEC suite from autodesk you'll already have access to it. Otherwise at $40 a month starting with a 30 day free trial, it's worth while for this kind of operation alone.
If you're using Register360 for registration you can get to .RCP by exporting an .e57 and importing that into ReCap... That's a pretty reliable and easy, if slightly time consuming work-flow.
smacl
Full Name: Shane MacLaughlin
Has thanked: 55 times
Been thanked: 58 times
Post by smacl »
We've tools to extract high resolution ortho-images from SCC, if you skip to about 2:20 in the image below you'll get an idea of how this works. In this example we're colouring by normals to get an orthoimage, but the same technique can be used with available RGB to get an orthophoto. It is a very quick and easy way of adding value to client CAD deliverables, particularly facades and elevations. In the example below the JPEG we create is 20,000 x 8,000 pixels which is suitable for drawing over in a CAD package that does not have a point cloud engine.
youtu.be/Hn-OlFTXa_M
