combining drone and terrestrial data
rainscan
Full Name: Jeff Rains
Company Details: Rains Architecture
Post by rainscan » Sat Jul 14, 2018 7:42 pm
I have a Leica BLK360 scanner and a drone using Pix4D. In my current project, I need to combine the point clouds. I am using Cyclone 360 Register on my desktop. I have output multiple file formats from Pix4D to try, LAS, XYZ, etc. When I try to import any of them nothing happens - no processing, no error message, no lock-ups, nothing. I'm wondering if anyone on this forum has any suggestions for me. I thought maybe there could be a setting I'm missing, or maybe the file size is too large, but I can't find anything in either program's help files or forums.
Felix_the_Cat
Forum Supporter
Forum Supporter
Full Name: Felix
Re: combining drone and terrestrial data
Post by Felix_the_Cat » Sun Jul 15, 2018 10:41 pm
So to cover the simple stuff -
After you drag and drop the files you have to highlight them with the check mark and hit that big red button on the bottom right of the screen (it has an arrow on it maybe?) to actually then go ahead and process the files. Otherwise it just sits there and stares at you and does nothing.
I imagine you have done that, but just in case....
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Post by stevenramsey » Mon Jul 16, 2018 10:04 am
Reg360 currently doesn't support un structured data. you will need to use Cyclone Register to do this. I'm sure your local person can arrange a temp license for you
Steven Ramsey
Work steven@4DMax.co.uk
Mobile +44 7766 310 915
sheartab
Full Name: Sheartab
Company Details: Arch Eng Design Firm
Country: US
Post by sheartab » Mon Jul 16, 2018 6:10 pm
Recap would be the way to go I think. I have used structured and unstructured scans successfully in Recap.
rainscan
Post by rainscan » Tue Jul 17, 2018 5:07 am
Thanks, but nothing happens when I drag and drop or import. The button does not turn red. It just ignores me.
rainscan
Post by rainscan » Tue Jul 17, 2018 5:08 am
I will try it in Recap, but I bought the Leica package because I was having so many problems with Recap.
rainscan
Post by rainscan » Tue Jul 17, 2018 5:13 am
That is disappointing. I bought it direct from Leica and I think the Leica sales rep misled me. I was told Reg360 would do any basic importing and cleanup that Cyclone does, it just doesn't have some of the more advanced tools. I am admittedly a newb, and I suppose they'll say I wasn't specific enough in my questions. It is true that I didn't ask about specific file formats, but I did mention drone data. So glad I spent thousands on something I still can't use.
rainscan
Post by rainscan » Tue Jul 17, 2018 5:17 am
Looks like CloudCompare might work. Bit of a learning curve to get the two point clouds aligned, but at least I can see both of them in the same workspace.
neeravbm
Full Name: Neerav Mehta
Company Position Title: CTO
Post by neeravbm » Tue Jul 17, 2018 5:54 am
I have access to Recap. If you have problems with CloudCompare, send me the point clouds and I can help using Recap.
Neerav Mehta
CTO, Indoor Intelligence
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 » Tue Jul 17, 2018 6:36 am
When I combine laser scans and drone photogrammetry I do no register them together.
I either use the same GCP net on both projects, or I register laser scans, and create GCP for photogrammetry from the laser scan project.
I then create the photogrammetry project and export both clouds.
I import the clouds in Arena for Rhino or Pointcab, so they don't need to be registered in the same tool.
