Lost my way with Pointools render settings
Discuss all Bentley Pointools related issues here.
Postby richthegoose » Fri Jul 15, 2011 8:26 am
Can anyone help me with Pointools animation and render settings that will quickly render a good quality animation into a reasonable file size.
Ultimately I would like a 720x1280 25fps avi file.
I have tried various settings for example:
Motion Blur quality: standard; No anti-anti-aliasing; Codec: full frames
A 45 second fly-through is taking over 2 hours to render on a high spec machine and churning out a 3GB file – there is no way a 45 second avi file should be 3GB!
Shorter files (10 seconds) come out at about 1GB, at this size they are small enough for me to convert using Adobe Media converter, with no compression and no apparent loss of quality these go from 1GB to 37MB just by re-saving as a new avi file, though 37MB is still ridiculous for a 10 second clip.
I can’t seem to see where I am going wrong, any help will be much appreciated.
Rich
richthegoose
Full Name: Richard Clark
Company Details: Metropolitan Police Service
Company Position Title: Collision Investigator
Re: Lost my way with Pointools render settings
Postby Greg » Fri Jul 15, 2011 9:29 am
Hi Rich
The 'Full Frames' Codec is uncompressed. Try switching to any other codec for much smaller file sizes!
Here is some usefull advide on codecs in Pointools from the Pointools Forum:
http://www.pointools.com/forum/viewtopi ... codec#p836
Changing the anti-aliasing and motion blur will have little effect on the output size but will effect the render times.
I hope this helps you?
Greg
Full Name: Greg Painter
Company Details: apr services
Company Position Title: 3D CAD Manager
Postby DanCutler » Mon Jul 18, 2011 4:45 pm
great advice thanks Greg,
you can also find an interesting thread about codecs and rendering large resolution movies from David at ATS (a Swedish Pointools sales partner) on the Pointools forum.
I recommend having a read - http://www.pointools.com/forum/viewtopic.php?f=17&t=305&p=836&hilit=codec#p836
8-)
DanCutler
Full Name: Dan Cutler
Company Details: Bentley Systems
Skype Name: dan_pointools
Postby RussellHall » Tue Jul 19, 2011 9:52 am
by exporting the images and recompositing them using vdub or similar we are managing .wmv / 1200x1024 at 30mb per min.
RussellHall
Full Name: Russell Hall
Company Details: MLS
Company Position Title: 3D Spatial data monkey
Postby richthegoose » Thu Jul 21, 2011 6:23 pm
OK, I seem to have got there at last.
I’m using a 64bit system and the method described by joohansson didn’t seem to work. The K-lite Codec package was all 32 bit codecs and none of then showed up in Pointools, there was a K-lite 64 bit package but that didn’t include a 64 bit version of the x264 codec.
In the end I downloaded the Xvid codec mentioned here: viewtopic.php?f=76&t=3439#p14151 . I tried rendering to jpegs then using Adobe Premier Pro CS5 but the file sizes went silly again. In the end I just rendered straight to avi with the Xvid codec in pointools. This produced beautiful HD videos at very manageable file sizes. I am very happy with the results.
On an aside I really like the free avi converter mentioned on the thread, it seem to work much better than Adobe Media Encoder which I had been using up to now.
richthegoose
Postby christopherbyrne18 » Fri Jul 22, 2011 2:44 am
Its the way to go I reckon,
Whats the point exporting out of Pointools as images to process in another package? Its just adding another unessary step when the 64bit xvid codec does a great job.
Chris
christopherbyrne18
Full Name: Christopher Byrne
Company Details: Rio Tinto Iron Ore
Company Position Title: Specialist Surveyor - Mine Engineering
Postby ArminB » Sat Aug 06, 2011 12:38 pm
Hi Steffen
Here is a guide for fast rendering in Pointools:
first: go into the render settings for the codec to check if xvid is available. If yes, go on with Step 3.
second: Install the K-lite code package http://k-lite-codec-pack.softonic.de/
third: To reduce set the desired resolution in the animation settings, turn motion blur from the rendering time.
fourth: Now choose xvid from "drop down" menu in the render setting, press Configure and set the slide switch to second, then close
5th Given name and press button to start rendering.
Kind Regards,
Armin
ArminB
Full Name: Armin Bethke
Company Position Title: Social Marketing
Return to Bentley Pointools
Who is online
Users browsing this forum: No registered users and 2 guests
Stay in touch    RSS feed    Twitter    Youtube    Linkedin
LSF SPONSOR
DouZa Webdesign
