Cyclone to Autocad 2011 file conversion
- I have made 40-50 posts
- 15
- Full Name: Matthias Koksch
- Company Details: kubit www.kubit-software.com
Re: Cyclone to Autocad 2011 file conversion
Graeme,
I think this is how Tilo understood and answered your question.
Your clients do not have to buy any software (besides being on AutoCAD 2011). They will need a PCG file from you, what they can attach to their DWG's. So if you create the PCG from your scan projects and deliver this to your clients all should be fine.
Of course AutoCAD/autodesk should come with a direct import for a Cyclone project and Leica should have a PCG export from Cyclone to make it comfortable for their users. May be both wait for the other to move first.
We just made these conversion routines to help our clients, it is not a big deal.
Matthias
Matthias
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
As Autodesk are the only people that can make the PCG file and have not supplied the codec to anyone other than Kubit which means additional software purchase. you would have thought that they would have allowed for simple ASCI based file import, LAS is an industry standard for Ariel data, the rest are vendor specific propriety formats, they seem to have gone out of there way to isolate the source of all the data they are so proud of saying they can now read,Matthias wrote:Graeme,
Matthias
Remember Plain Autocad and Civil/Map use different engines and can import different types of data.
I am sure we will see Autodesk adding additional import formats with there subscription service and maybe Scanner manufacturers will add additional exports. PCG may be a great new storage format but with no way to get the data in what is the point of Autocad having pointcloud capabilities .
- Tilo
- 15
- Full Name: Tilo Pfliegner
- Company Details: FARO 3D Software GmbH
- Company Position Title: Software Developer
That's perfectly true.stevenramsey wrote: As Autodesk are the only people that can make the PCG file
And this is not true. We don't have the codec or format specification at all, we simply use the sparse API they (Autodesk) currently (and publicly ) deliver.stevenramsey wrote: and have not supplied the codec to anyone other than Kubit
I fully agree with all of you which are wondering how Autodesk could not provide a simple ASCII import, we were wondering as well. But that's the fact - at least in the 2011 version.
Tilo Pfliegner
www.faro.com
www.faro.com
- stevenramsey
Ok here is a challenge to the pointcloud coding Gurus out there if Autodesk have made the ability to create the pointcloud format in there publicly? available API how about a free plugin that will import the ASCII data.
- Tilo
- 15
Go ahead, here is all you need to know:
http://usa.autodesk.com/adsk/servlet/in ... eID=123112
http://liblas.org/raw-attachment/wiki/W ... at_v11.pdf
http://www.cplusplus.com/reference/iostream/ifstream/
Maybe this is the information Graeme originally wanted to have, I don't think so...
However if anyone finds an easy - and free - way to convert the Cyclone data to PCG files, please let us know. In the meanwhile we should let this matter rest and going back to doing more serious things
Tilo Pfliegner
www.faro.com
www.faro.com
- JosephChumbley
- 15
- Full Name: Joseph Chumbley
- Company Details: Lockheed Martin Space Systems Co
- Company Position Title: Mech Eng Senior
I believe you can thank a long standing feud between AutoDesk and Lieca for the lack of supported file formats, and a strong marketing push by Faro teaming up with Autodesk on a number of their internal programs for the formats they do support.
- 15
- Full Name: Scott Kerr
- Company Details: Babcock International Group
- Company Position Title: Laser Scanner Technical Lead
- Country: Scotland
- Skype Name: SKerr
I beleive what Graeme wanted to know was this.......can we/how do we, export our Cyclone files into a format that can be read in AutoCad 2011?
From the answers given, there is no straight export/import option.
- Leonardo.Inocencio
- I have made 70-80 posts
- Full Name: Leonardo Campos Inocencio
- Company Details: UNISINOS University
- Company Position Title: Survey Engineer Professor
- Country: Brasil
Hello to all,
I downloaded the trial version of Autocad Map 3D 2011 to test the point cloud support. We use Cyclone and to try to make it work i installed PoinTools, imported and converted the PTS file to POD file, then exported to LAS file, a format available at the import format list in Autocad. Went to INSERT, POINTCLOUD and INDEX DATA. Tried both formats PCG and ISD but didn´t work. Someone had successfully imported a point cloud to Autocad from a diferent origin?
- Faraz
- Full Name: Faraz Ravi
- Company Details: Bentley Systems
- Company Position Title: Director Product Mngmnt for Point Clouds
We need to remove that LAS export from Pointools products, its not a standard LAS, it was a proposed LAS extension for terrestrial scan data but was never adopted.
We're going to take a look at how we can enable our users to convert a range of formats to work in AutoCAD. Despite having a product that plugs into AutoCAD ourselves which gives much better visual fidelity, performance and functionality it may be still something we do for users that decide they want to use the native AC support for point clouds.
btw. Users of the Bentley point cloud support in Microstation (currently in beta) already have a wide range of formats to choose from including generic ascii formats and hardware vendor specific formats.
- I have made 60-70 posts
- Full Name: Chris Mounts
- Company Details: PMC
- Company Position Title: Scanning Director
- Been thanked: 5 times
For any Bentley users out there I can say that Pointools in MicroStation is pretty awesome. Far better than whatever AutoCAD is trying to do. Hopefully AutoCAD gets there stuff together though. Having decent native support for casual users will help all of us. Now if only I could have points in Revit...
