Hi All,
how are you?
Does anybody know how to mount a laser scanner on a steel beam or steel truss?
Thank you so much for your help!
Mount a laser scanner on a beam
- Full Name: Viviana Vumbaca
- Company Details: Thornton Tomasetti
- Company Position Title: Senior Engineer
- Country: US
- Skype Name: viviana7982
- jcoco3
- Full Name: Jonathan Coco
- Company Details: Consultant
- Has thanked: 70 times
- Been thanked: 157 times
Re: Mount a laser scanner on a beam
Depending on the size of the beam and where on it you intend to mount the scanner a simple beam clamp from the hardware store will work. Some of them even have a 3/8NC threaded hole in them, so the scanner can be easily bolted to it with a short piece of all thread.
Here is one we made that is very customizable: http://www.laserscanning.org.uk/forum/v ... =49&t=5251
Mounted on a hand rail: Foot mount;)
Another possible solution is using some telestrut to make your own clampHere is one we made that is very customizable: http://www.laserscanning.org.uk/forum/v ... =49&t=5251
- Full Name: Richard Hekimian
- Company Details: Ironbark Heritage and Environment
- Company Position Title: Senior Archaeologist
I mounted ours on some box- and tri-truss for different projects using a plank of plywood with a bunch of holes drilled in it for U-bolts.
Good luck!
Easy and cheap!Good luck!
- I have made 30-40 posts
- Full Name: Ben Meyer
- Company Details: Craig and Rhodes
- Company Position Title: Registered Surveyor
We've used this clamp for a scan over the 27th level parapet of building. Our main concern was ensuring the scanner was adequately secured to prevent potential safety issues below.
- Full Name: Casey Cockrell
- Company Details: Land surveying firm in North East Texas
- Company Position Title: Owner RPLS
Ric, you didn't have any problems scanning with the scanner horizontal to the beam? Because that would be awesome to just hang that Focus off the side of a railing.
- Full Name: Kim Eilif Pedersen
- Company Details: Naturstyrelsen Bornholm
- Company Position Title: Fuldmaegtig
- Country: Denmark
Hi from Bornholm, Denmark
My first time on this forum. Trying to Work out how to post Photos.
If it Works, this is how i do it in pláces hard to reach.
Hope it Works........
[img]https://plus.google.com/u/0/photos/1084 ... 6447540781][/img]
- Country: Denmark
