Mount a laser scanner on a beam
Discuss FARO hardware here.
Viviana
10
Full Name: Viviana Vumbaca
Company Details: Thornton Tomasetti
Company Position Title: Senior Engineer
Country: US
Skype Name: viviana7982
Post by Viviana »
Hi All,
how are you?
Does anybody know how to mount a laser scanner on a steel beam or steel truss?
Thank you so much for your help!
jcoco3
12
Full Name: Jonathan Coco
Company Details: Consultant
Has thanked: 70 times
Been thanked: 157 times
Re: Mount a laser scanner on a beam
Post by jcoco3 »
Depending on the size of the beam and where on it you intend to mount the scanner a simple beam clamp from the hardware store will work. Some of them even have a 3/8NC threaded hole in them, so the scanner can be easily bolted to it with a short piece of all thread.
Another possible solution is using some telestrut to make your own clamp
Here is one we made that is very customizable: http://www.laserscanning.org.uk/forum/v ... =49&t=5251
Mounted on a hand rail:
Foot mount;)
Ric
10
Full Name: Richard Hekimian
Company Details: Ironbark Heritage and Environment
Company Position Title: Senior Archaeologist
Post by Ric »
I mounted ours on some box- and tri-truss for different projects using a plank of plywood with a bunch of holes drilled in it for U-bolts.
Easy and cheap!
Good luck!
benmeyer40
10
Full Name: Ben Meyer
Company Details: Craig and Rhodes
Company Position Title: Registered Surveyor
Post by benmeyer40 »
We've used this clamp for a scan over the 27th level parapet of building. Our main concern was ensuring the scanner was adequately secured to prevent potential safety issues below.
SouthernSurvey
10
Full Name: Casey Cockrell
Company Details: Land surveying firm in North East Texas
Company Position Title: Owner RPLS
Post by SouthernSurvey »
Ric, you didn't have any problems scanning with the scanner horizontal to the beam? Because that would be awesome to just hang that Focus off the side of a railing.
Kim Pedersen
11
Full Name: Kim Eilif Pedersen
Company Details: Naturstyrelsen Bornholm
Company Position Title: Fuldmaegtig
Country: Denmark
Post by Kim Pedersen »
Hi from Bornholm, Denmark :)
My first time on this forum. Trying to Work out how to post Photos.
If it Works, this is how i do it in pláces hard to reach.
Hope it Works........
[img]https://plus.google.com/u/0/photos/1084 ... 6447540781][/img]
Kim Pedersen
11
Country: Denmark
It diddent.....
Return to “FARO”
