Colors from Scanner not displaying correctly.
- Full Name: Clint Hansen
- Company Details: Land Solutions
We are using a C10 with Cyclone 7.1.1. I recently completed a topo survey with about 30 scanworlds, and everything worked great. However, in my first scanworld when i try to apply the colors from the scanner to the scanworld, the points all come up green and do not have the photo colors associated with them. All the other scanworlds work fine and apply the colors from scanner correctly, but the 1st one will not. When i look at the images in the images folder, the multi-image shows up with the 360 degree photo just fine. I did take the mult-image with the C10 setup several times, due to messing with the resolution and intensity, but the final image that i took is what shows up in the multi-image. Does onyone out there have a solution? When i create a TruView of the scanworld, the colors come is as bright green, and are not a viewable image. Nothing can be made out. The other Tru-Views look great. Thanks.
- TimBeach
- Full Name: Timothy Beach
- Company Details: Hollis
- Company Position Title: Senior Associate - Measured Surveys
- Has thanked: 4 times
- Been thanked: 4 times
Re: Colors from Scanner not displaying correctly.
Try right clicking on the multi-image and choose apply multi-image it should 'burn' the colours onto the scanworld.
Tim
Tim
- Phil Marsh
- Administrator
- Full Name: Phil Marsh
- Skype Name: phil.h.marsh
- Has thanked: 119 times
- Been thanked: 36 times
Tim,TimBeach wrote:Try right clicking on the multi-image and choose apply multi-image it should 'burn' the colours onto the scanworld.
I had this issue last week. And after right clicking and applying multi-image it worked but why does this only happen to a few scans? Is there somthing on import in the preferences that needs to be ticked/selected?
- Full Name: MELCHOR J. AGUILAR
- Company Details: Topomar Topografos
- Company Position Title: Laser Scanning Construction Survey
- Country: SPAIN
- Skype Name: raul-topo
Yes the problem that you have is because you take the photos with c10 at in this station you have a problem, like batteries, shut down the systems, windows c10 restart and yes you see the photos, you maked correctly the asociate with the scanwords but file of photos linked for scan was not correcly finished and this is the reason; I have other c10 and passed a few times this.
- Full Name: Donald Axtell
- Company Details: Insight 3D Survey
Yes, it worked perfectly. Thank you for the replies.
