Cyclone 7x Crashes on import
Postby rlasater » Mon Dec 05, 2011 9:10 pm
Cyclone 7.x (pce) must be started with a special switch in order to use a "shared" server instance. If you are having problems importing to a new database, or receiving the stack trace included below, check to make sure you have the database mounted on the "unshared" version of your server/workstation.
Unable to import file(s)
C:\_CYCLONE\1.zfs
There are errors reading file(s):
C:\_CYCLONE\1.zfs
File:C:\_CYCLONE\1.zfs
PCE: System.IO.IOException: Can't deserialize a stream.
Server stack trace:
at v.b()
at q.ProcessMessage(IServerChannelSinkStack sinkStack, IMessage requestMsg, ITransportHeaders requestHeaders, Stream requestStream, IMessage& responseMsg, ITransportHeaders& responseHeaders, Stream& responseStream)
at System.Runtime.Remoting.Channels.BinaryServerFormatterSink.ProcessMessage(IServerChannelSinkStack sinkStack, IMessage requestMsg, ITransportHeaders requestHeaders, Stream requestStream, IMessage& responseMsg, ITransportHeaders& responseHeaders, Stream& responseStream)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at LeicaGeosystems.ApiFramework.Services.IRRemotableServiceFactory.get_RemotableServiceInterface()
at LeicaGeosystems.ApiFramework.Servers.AggregatedRemotableServiceManager.Insert(Int32 index, IRRemotableServiceManager item)
at LeicaGeosystems.ApiFramework.Servers.AggregatedRemotableServiceManager.Add(IRRemotableServiceManager item)
at CsUtility.ConnectionManager.ServerConnection.AddClient(IRRemotableServiceManager remoteMgr)
at CsUtility.ConnectionManager.ServerConnection.AddClient(String url)
at CsUtility.ConnectionManager.ServerConnection.GuaranteeConnection()
at CsUtility.ConnectionManager.ServerConnection..ctor(ServiceLogin login, String machineName, Int32 portNumber, Int32 id)
at CsUtility.ConnectionManager.GetConnectionToMachine(String machineName, Int32 portNumber)
at CsUtility.ConnectionManager.GetConnectionToMachine(String machineName)
at PceDbLink.{ctor}(PceDbLink* , ImpClientServerConnection* p_conn)
at PceUtils.FileNameAndDatabaseToUrl(String fileName, ImpClientServerConnection* pConn)
at ImportPCSPartsExternal(basic_string<char\,std::char_traits<char>\,std::allocator<char> >* fileName, ImpClientServerConnection* pDestDb, list<CyImportScanData\,std::allocator<CyImportScanData> >* rScanData, ImportScanOptions* pImportScanOptions, ImpProgressUpdater* pUpdater)
Richard Lasater
President
Smart GeoMetrics
a division of Smart MultiMedia, Inc
richard.lasater@laserscanning.org.uk
rlasater
Full Name: Richard Lasater
Company Details: Smart GeoMetrics
Return to Leica Cyclone
Who is online
Users browsing this forum: No registered users and 1 guest
Stay in touch    RSS feed    Twitter    Youtube    Linkedin
LSF SPONSOR
DouZa Webdesign
